Williams1419
641 Bhp/625 Lbft High spec 2006 Subaru blobeye Wrx
£15500 Ono
641 BHP 625 lbft
570 BHP on v power
6 speed box built by API at 91k
Engine rebuilt and height up rated
by Andy Kindon
mapped by Bob Rawle
Engine has done just over 11k since being built
Alcatek ecu with anti lag and launch control enabled
2 map settings - Meth and v power
Anti lag switch
Launch control switch
Map switch
Recently replaced - within last 5 months
millers 10w-60 nanodrive engine oil with hks oil filter - both changed every 3-4 months
All 4 spark plugs
Front Calipers refurbed and 5.1 dot brake fluid
Clutch and flywheel
Engine spec
Latest generation Subaru EJ257 forged
induction hardened crankshaft
ACL race series main and big end bearing set
2.5 Closed deck block plating + 14mm headstud conversion
RCM uprated head gaskets
Up rated oil pump
Wrx blobeye Cylinder heads ported and fitted with STI version 6 valves, springs, lifters and Kelford Race cams
Rcm thermosta 70 degree open
breather system re plumbed
Oil catch tank fitted
86m black intake hose turbo
Turbo Owen development ODGT3583HTA
Cdf pulley kit
Competition clutch kit Stage 3 & competition lightened flywheel
3 port boost solinoide classic
4 bar map perrin sensor
Hdi front mount intercooler with
candy red pipe work
candy red overflow tank
K&n large corn filter with custom pipe work
Rcm headers
Harvey smith up pipe wrapped
Black washer bottle
Candy red battery clamp
Carbon Candy radiation pannel, fuel box cover grill and boost bracket
Jdm 1 piece intake manifold with tgv delete built in
20mm rcm manifold spacer
Candy red alternator with black bracket
Air con remover
3 inch slip jointed cat back system matched to a 3 inch down pipe bell mouth
Samco water hoses set blue
Sti alloy oil cap
Sti blitz header tank cap 1.3 bar
Engine dress up kit bolt & washers
Fuel system
1200cc motosport injectors
Fuelab fuel pressure regulator with syvecs gauge
genuine walbro 440 fuel pump Mod to sit further down tank and direct live to up rate voltage
Fuelab external fuel pump with external fuelab filter
Fuel swirl pot in boot on relay and fuse
Full Teflon braided black fuel lines 8mm feed and 6mm return lines with torque Teflon AN fittings
Roger Clark parallel fuel rails
Handling
Bc coilovers br series with rear extenders
White line anti roll bar and bushes rear 3 way adjust
Super pro solid drop links rear
up rated super pro drop links gold on front
Tein front strut brace
Up rated engine mounts
Body styling
Headlights detangled black with led side light and rear number plate lights
Debaged boot
Front tow strap
Jap plate
Wide track archs and rear bumper
Sti side skirts
Sti fog covers
Sti winglets
Sti bonnet vent
sti front bumper mesh
Hella horns candy red
Prodrive mudfaps in black
Front splitter gloss black
Ht auto side skirt extenders and rear spats
Ht auto exhaust trim
Ht auto diffuser
rear spoiler with Perrin wing stiffe X2
Debaged grill & boot
Deano limo tint on back windows
light tint on front windows
Smoked side indicators
Brakes
Brembo front and rear calipers
Black diamond grooved discs and ferrodo ds2500 pads
braded brake lines all round
5.1 dot brake fluid
Wheels
Xxr 530 8.75 530 alloys in candy red with flake - could do with refurb but hasn’t bothered me
5mm and 3mm spacers With
Epman formula nuts M12 x 1.25 IN polished red
Sound system
Pioneer SPH-DA120 smartphone head unit with rear view camera upon reverse
Pioneer door speaker front and rear
Amp & Subwoofer in boot
Interior
Center gauge pod with carbon insert
Prosport gauges - oil temp, oil pressure, battery & boost gauge in pillar pod
Hks turbo timer
Sti version 8 seats
Sti clock with Rev counter beep
Sti version 9 steering wheel
Sti mats
Strobe kit
Sti gear surround
Sti 6 speed gear knob
07432751509
Share this post
Link to post
Loading...
