oil pressure
im just wanting to no if it is ok that the oil pressure gauge is reading 100 witch is max is this ok or any concern i need to no
100 in PSI I take it is fine at start up. Once warm it should drop and move up and down as your revs go up. But don't worry if its stuck at 100 to much might be a faulty sender. I would only worry if it was at 0 that's not good at all :D
