I'm thinking of upgrading the brakes on my 1997 WRX STI Imported GC8, i would like to retain the original calipers and mounts, just want to replace the discs and pads. there are lots of aftermarket options available, not sure if the imported version is different  to the UK version or WRX? any preference on size/make? Any help much appreciated
cheers Yoss
cheers Yoss
hi
 do you do a lot of track time or use the go fast peddle a lot?  and have you still got the 4 pot calipers or are they BREMBOS?
Hi
i dont do any track time, but the loud peddle does get a little use! it is still on the standard STI four pots  which I'm not looking to upgrade, just wondering what manufacturer disc/pads i should go for via the internet, or do i just pop down to the local autofactors and order from there??
cheers yoss
yeah they are the same as a facelift uk impreza, I use godspeed on mine
