Electric window trouble.
Has any one else had this problem when I open the drivers side window it won't go back up unless I turn the ignition off then back on. Help would be great.
I'd take the door card off and have a look might need to test the switch see if it's losing power to it after awhile. Or maybe the motor
I have a similar problem with my 2003 WRX. Intermittently, the drivers window won't go down unless I drop the rear drivers side window. I had read somewhere that this is quite a common problem and has something to do with the wiring getting trapped and worn between the front and rear doors?
Not had a chance to take the door panel off yet to see how true this is, but it's really annoying
Mine was the switch in the end replaced that and now it works fine.
