Has any one else had this problem when I open the drivers side window it won't go back up unless I turn the ignition off then back on. Help would be great.
I'd take the door card off and have a look might need to test the switch see if it's losing power to it after awhile. Or maybe the motor
I have a similar problem with my 2003 WRX. Intermittently, the drivers window won't go down unless I drop the rear drivers side window. I had read somewhere that this is quite a common problem and has something to do with the wiring getting trapped and worn between the front and rear doors?
Not had a chance to take the door panel off yet to see how true this is, but it's really annoying
