Perrin wing stiffi install help
robwrx
No mines on a genuine STI spoiler but if you have a replica that's the same size well almost identical I can't see it being a problem some good strength double sided sticky foam or equivalent should do it :) But would check what spoiler you have first I know the replica on the the Blobeye would be too small it doesn't stand as high.
So if it's like this should fit fine. Can't find a picture of the one on the blobeye but it sort of looks more P1ish style and sit's lower.
Yeah easy enough I'd have thought Can be easier you the top part of the wing and be removed otherwise be a little bit more tricky getting them in as you will need to slide them in with a bit of force with whatever you have used to stick them on with. So be a little clean up too :D
My spoilers a rep i think as theres no screws on the top section but mine fitted perfectly as gambit said bit of tape holds them in , i just slid them in and then removed the tape bit fiddly but can be done
