Garage Clear Out
Hi there, I am having a bit of a clear out so I have the below available. I have priced up all items but obviously will always listen to any sensible offers. The larger/heavier items would be pickup only but I don't have a problem posting any of the smaller/lighter items, quotes for postage would be done at the time. Paypal is fine but I would need to factor in the fees that come along with that on top of the agreed price or of course cash on collection is also fine.
All parts are from Subaru Impreza's, mostly are newage but there are some classic parts in there as well. Any questions just let me know and thanks for having a look.
Perrin RBCS Pro - Unknown condition £40
Throttle Body - Part No RTT60-03, Part No 22627AA70 - £25
STI TGV - £50
Front Belt Cover - £25
Belt Cover - R/H - £20
Belt Cover - L/H - £20
Belt Cover L/H - Part No 13575AA044 PA/13569AA044 - £20
Belt Cover Rear R/H -Part No 13573AA62 PA/13568AA72 - £20
Belt Cover - £20
STI Mud Flaps - £20
AC Belt Cover - £15
Air Con Pipes - £30
Water Pump - £25
Coolant Filler Tank - £20
HKS Sequencial Blow Off Valve - £45
EGR Valve - Part No K267 - £15
Subaru Cap - £5
Silver STI Oil Cap - £5
Red Oil Cap - £5
Crossover Coolant Pipe (Appears to be 2001 - 2005)- £20
Crossover Coolant Pipe 2 (Could also be 2001 - 2005) - £20
Crossover Coolant Pipe 3 (Appears to be 1993 - 2001) - £20
Oil Filler Tube - £15
Rocker Cover R/H - £30
Boost Control Solenoid - Part No 16102AA090 - £40
Front Drop Link Set - £10
Gasket Turbo Inlet - £5
Gasket Turbo Manifold to up Pipe - £5
Gasket Cylinder Head To Exhaust X2 - £10
Camshaft Sprocket Set (Hex Shaped) - £100
Camshaft Sprocket Set (Star Shaped) - £100
Crankshaft Sprocket X2 - £15 each
Automatic Belt Tensioner - £25
Various Heatshields - £5 each, whole lot for £20
Plastic undertrays - Gearbox £20 and Engine £50
Clutch Cover X3 - £50 each
Clutch Disc - £40
Alternator - Part No 23700AA280 - £25
Alternator - Part No 23700AA390 X2 - £25 each
Air Con Pump - Part No 506221-2350 - £25
Air Con Pump - Part No 506221-3032 - £25
Starter Motor - Part No 23300AA380 - £20
Power Steering Pump - £35
Inlet Manifold with Throttle Body and Wiring AB910 - £50
Inlet Manifold with Throttle Body and Wiring AB171 X2 - £50 each
http://i301.photobucket.com/albums/nn69/tgordine/Impreza%20Parts/Original%20Files/IMG_6015.jpg
http://i301.photobucket.com/albums/nn69/tgordine/Impreza%20Parts/Original%20Files/IMG_6016.jpg
http://i301.photobucket.com/albums/nn69/tgordine/Impreza%20Parts/Original%20Files/IMG_6017.jpg
http://i301.photobucket.com/albums/nn69/tgordine/Impreza%20Parts/Original%20Files/IMG_6018.jpg
http://i301.photobucket.com/albums/nn69/tgordine/Impreza%20Parts/Original%20Files/IMG_6019.jpg
Skid Plate - £40
Spats Strut Brace - £15
Exhaust Intermidiate Pipe - £40
Exhaust Front Up-pipe - £20
Exhaust Front Assembly X2 - £50 each
Subaru STI Backbox - £30
Longlife Stainless Steel Backbox - £75
Magnex Stainless Steel Backbox - Part No XSS05/5J - £75
Catalytic Converter & Centre Pipe - £80
Neutral Switch - £25
Gearbox - 9R-TY754VN5AA - Unknown condition £75
Factory Head Unit - £20
TD04L Turbo (only available once I have rebuilt it) - £100
Door and Motors - £50
Injectors - £40
Lambda Sensor - Part No 22690AA520 - £50
http://i301.photobucket.com/albums/nn69/tgordine/Impreza%20Parts/Original%20Files/E070ECC9-4B77-4AF1-B64A-17D71CDB8971.jpg
http://i301.photobucket.com/albums/nn69/tgordine/Impreza%20Parts/Original%20Files/A54F7CFC-86CA-4AFF-B1B8-E4FEFCEE9ED6.jpg
Forgot to mention that I also have 2 EJ20 blocks which have blown bottom ends, if anybody is interested in them at all let me know, or if people want anything like the sump, dip stick, dip stick tube...etc then just let me know if not up the scrappy they go :D.
  • 2 months later...
Gasket Turbo Manifold to up Pipe, Gasket Turbo Inlet and STI mud flaps now sold
Perrin boost controller and catalytic convertor now sold
Magnex exhaust now sold
Dam I would have had the flaps :) can't justify 80 quid for a set :(
Might have the belt cover. Just trying to sell Halo 5 at the minute :)
hey buddy, would any of the exhausts go onto a Forester (2003)? Thanks chap.
I had a quick look around online and it would suggest that they will fit but modification will be required to at least the hangers
Hi I'm new to subaru forum. Thought I'd use these to help me find an engine for my version 2 wrx import. Are u breaking the whole engine or do u have or know of a complete engine or semi complete? Thanks matt
Hi and welcome to the forums, all I have in the way of engines is what I have listed above. So I have got a few parts to help build it up but I don't have anything complete.
