Changing ignition barrel
Hi guys
OK so the barrel needs to be changed as I snapped key. Is it just a case of drilling out the bolts on the clamp around the steering column? Or am I missing something. Also if the scrappy don't have a replacement is there another make I can use or somewhere on the Internet.
You might be able to get the snapped key out with some very fine drill bits from the pound shop,put one or two down barrel then rotate anti clockwise they should grab on to key and draw it out that's how locksmiths do it,,worked for me once with a bit of trial and error😀
The original key was worn down I had a spare cut before I snapped it but it never worked
But thanks for the advice
