Abs ring
Hi guys im Lucas from germany 🙂
im searching for an abs ring. diameter outside is 140mm (14cm). diameter inside is 120mm (12cm). the ring is fixed by 5 bolts.
im making a gearbox swap from 5 to 6gears and also  a brake swap. (sti swap)
the new abs ring is damaged and i have problems in germany to get a new one, because i have not the car number.
it would be nice if someone can help me. i need the abs ring or the partnumber so i can buy it in england.
sorry for my bad english...
Thank you 😄
