Hi All,
new member post, so please be gentle 😀
I've recently moved from a 2010 Outback to a newer 2019 Outback and I'm being driven mad by some noises that hopefully someone here can advise me on, give feedback on, laugh at me, etc.
First one is annoying wind noise coming from the driver's pillar, wing mirror, etc. A quick search suggested a potential missing seal - is this common and if so, easy to rectify or do I just have to live with it?
Second one is a really annoying knocking coming from the glove box area when going round corners - every time I go round corners, there's seems to be a knock - almost like when the adapter for the locking wheel nut is loose in the glove box. This happens when the glove box is empty. There does seem to be some side to side play in the glove box, but not enough I think to make the noise. It really is driving me insane, so any thoughts / ideas very welcomed.
Apart from these noises, really loving the new (to me) car, well apart from moving from a diesel to a petrol and the significant reduction in mpg!
Cheers,
Allan
Sorry to hear you've had those issues with your OB.  I too have a Gen5 OB from nearly new and can't say I've had those issues so I don't think they're model specific.
Regarding the wind noise, a seal missing or damaged seems possible, or does the window on the driver side, while appearing fine, actually drop a few mm from being completely closed?  Maybe it sticks or the actuating mechanism stops it just short and so needs to be reset?
Re the glove box.  If it is loose, this seems to be unusual and while not the source of the issue, I wonder if the loose fit means that a previous owner has removed it to do some work behind and it, or something behind, hasn't been refitted firmly? If the noise only occurs when the glove box is empty, maybe that 'emptiness' is acting as an amplifier for something loose and moving behind or under?
Hope you get it sorted.
Morning,
thanks for your feedback. When I get an opportunity, I'll investigate both options.
The noise from the glove box occurs full or empty (mind you I do find the size of the glove box quite small compared to the previous model and other cars!)
Cheers, Allan
i have a 2022 outback and get the same noise when cornering, as if something is rolling around as you say.
  • 5 months later...
Welcome! I also have an Outback and I had exactly the same problem with air noise: it was a poorly positioned gasket at the level of the rearview mirror, easily adjusted with a little thin insulating foam. For the noise on the glove compartment side, I had to wedge the rear with adhesive felt, it was indeed a side game that hit bumps or cornering. Nothing serious, but annoying, I understand you! Otherwise, great car, even if the consumption stings a little in essence.
