2011 forester diesel engine replacement
Hi all new to the forum needing a little advice. Ive got a 61reg forester diesel with play in the crank !Removed! oil into bellhousing. Ive found an engine with 109k out of a 60 reg not too far to collect this week. Im wondering will it fit and what will need swapping over if it doesn't ? I know the injectors probably will or get the replacement engine ones coded to the ecu but is there anything else I need to know ? My engine is already out ready for the donor
Just a bit oily in there will be de greasing and cleaning up tomorrow
