2003-2009 Outback Rear Subframe (20152AG000)
Long shot, but looking for a used rear subframe for my Outback. Thing has crumbled to dust! Used would make more sense as I'm driving it to Ukraine where it'll be used in evacuations. Basically, it likely only has a maximum of 20K miles/1yr ahead of it, but it needs to do those reliably.
Can get a new one for ~£550 which isn't bad at all. Seems a waste to use a brand new one here, however. If anyone happens to have one of these, or one they've pulled off that's a bit crusty but structurally sound, please let me know, looking to move quickly, though. Paying £200-300 depending on condition!
I'm in Kent, willing to arrange a courier to collect if needed!
This part is found on:
Legacy/Outback - Legacy/Outback B13 (BL/BP) 2003-2009 / 2.0 SOHC EJ202
Legacy/Outback - Legacy/Outback B13 (BL/BP) 2003-2009 / 2.5 SOHC EJ253
Legacy/Outback - Legacy/Outback B13 (BL/BP) 2003-2009 / 2.0 DOHC EJ204
Legacy/Outback - Legacy/Outback B13 (BL/BP) 2003-2009 / 3.0 H6 EZ30D
Legacy/Outback - Legacy/Outback B13 (BL/BP) 2003-2009 / 2.5 Turbo EJ259
Legacy/Outback - Legacy/Outback B13 (BL/BP) 2003-2009 / 2.0 Diesel EE20Z
Hope you manage to source one - seems subframes are a massive issue on many makes of vehicles nowadays and chronic shortages worldwide at the mo, I guess they thought it would never have been an issue - last subframe I changed was on an old school Mini - rear one as the front ones didn't rust as the engine leaked oil over the subframe so wasn't an issue :-)
Thanks! I've had someone in touch who's breaking a 2007 Outback so may be in luck!
Bought this car recently and was gutted when I saw the subframe once it was up on a lift. The car had virtually zero corrosion anywhere you'd expect to find it. The subframe was completely rotten, two of the four mounting points had corroded the whole way though, never seen anything so dramatic and localised.
If it wasn't for how awkward the swap is, I'd probably be able to take it off, clean up and weld in some box section, but that'd mean it lurking around immobile for too long, and I'm relying on someone else for the lift.
Given it's expensive in terms of labour, I suppose ~£550 for a brand new one for a 20y/o car isn't too bad.
I have a feeling that leaking oil may have preserved the front end of mine too! Going to be doing the rocker cover gaskets, and I've been advised to change the trans oil pan too as it has a fairly minor leak, but apparantly there's a risk of it coming off (which I'm told can affect performance!) which wouldn't exactly be a roadside repair! I can get a new one for £50-90 though, which is fine, but if I can save a few hundred on the subframe that would be a nice win!
