P1560
I have error P1560
The description is below.
I've opened all connectors and sprayed CRC 2-26 (cleaner). Doesn't help. Also checked every single fuse both in the engine box and the box next to the steering wheel.
Note that I've just changed the glow plugs. I'm afraid I may have pulled too hard on some of the wiring but I haven't noticed any damage.
Other than that I'm planning to test all the relays. I'm reading about measuring tension on circuits but I don't know what it means / how to do it.
P1560
Definition:
Back-up Voltage Circuit Malfunction
Description:
Battery voltage ≥ 10.9 V. Engine condition - After engine starting. Low voltage condition of back-up power supply.
Cause:
Wiring harness between ECM and ground chassis needs repair.
Poor contact of the ECM connector.
Defective fuse.
Wiring harness between ECM and negative battery terminal needs repair.
