Engine fault
Hi all does anyone know we're to start on finding out how to fix fault code 12, car starts first time no problem it's not till it gets warm that it cuts out and very hesitant on boost. Checked the ecu and flashing up code 12
Any help would be nice cheers
Cheers buddy googled the issue and must stuff I looked at was pointing at the idle control valve so took it off gave it a clean and disconnected the battery for a few hours and see wat happens
yeah it has the obd slot it also has flash coding on it aswell.got 1 in work will have a check tomorrow see wat it says flash coding only pointing me in a general direction.it says stater switch fault but that covers many parts from the starter right back to the key.hopefully it will narrow it down a bit lol
Haha agreed
Handy you have one at work you can use I have to give my mate sexual favour's if I want to use his. That's why I got my self the Phone app for now ;)
lmao well safe to say ma scooby is a **** the obd would not read the ecu so i got lend o another 1 and that did not work ether so back to square 1.al just fone subaru on monday and pick 1 of there brains c wat they say
Well be boring if it was simple :)
