When I dip my clutch to pull up to lights, junction etc. The revs drop right down to nearly 0. Then the car revs back up to normal idling revs. It sits fine on normal idle/tock over. It's only when I dip the clutch when driving. Any ideas?
Mine does this when I dip the clutch, I just presumed it's a normal thing to happen. My car is mapped by Prodrive though?
I wouldn't of thought it's normal for the revs to drop to 0 and nearly cut out
I would almost put my life on it being the MAF or an air leak. But can be what Ash said among a few other things. But would say MAF
Unplug the maf while it's running and see if it stalls
Isn't that what you want though? Means it is at fault rather than something else yet to be found :P
Yeah, no light then I would check the throttle body first. Apparently the turbo covers it with oil over time or something
You won't always get an engine light with the MAF fault. And throttle body would be next clean the carbon build up from it
