will these fit..
5 x 114.318x8j et32 team dynamics of a hatch on to my widetrack blob sti?
I will have to check but I'm sure they won't I think they changed them slightly after the hawkeye
Just found out they are 18x8 114.3 et45!
05 STI
Width : 7.5J,
Diameter : 18 Inch
Bolt Pattern : Most 4 & 5 Stud Fitments
Offset : 37 to 45
2009
Width : 7.5J,
Diameter : 18 Inch
Offset : 37 to 45
Just had a quick look I'm unsure myself now I could have sworn there was a change. I know we had a discussion on this a couple years back will see if I can find the post :)
Cheers right....
The alloys are 18x8 114.3 with a et45 and tyres are 245/40/18 will they fit without any rubbing issues?
Ive had 225 40s 245 might be a bit to much. Anyway you can fit one or have a look
Not sure on the fitments as I'm fairly new to the world of Subaru's but here's a website I used a lot when changing wheels on previous cars. http://www.willtheyfit.com/
Handy if you have specs of old and new wheels and it gives you a picture to show you what the difference will be with your new offsets etc.
Hope it helps.
  • 4 weeks later...
ok I have overlooked. Widetrack is 5x114.3
