The front two seat belts squeal like you wouldn't believe everytime you pull them to put them on. I am presuming it is just a case of getting some lube on the roller part.......so the question is how do i get that roller bit? Where are the screws etc which need to be removed from the relevant panel.
Cheers.
I've been told to polish the plastic bits and yes probably a bit of lube on the moving parts
Ah no. I've sorted mine....you pull off the plastic guard (running from floor up to the seatbelt holder) and then shave off a plastic bar inside it that the seatbelt rubs against. Let me try and find a link. It took me 5 minutes to do
Cheers for that, i will be doing it tomorrow so will check back in with the results.
