2002-2003 4pots
Our friends across the pond would appear to have managed to get a 4pot swap using standard foz 16" wheels by using the newer flat wrx calipers with the stickers on as opposed to the older raised letter type.
Looks like you need the hanger bracket and new discs an it clears the inner face of the rim by a couple of mm
Does anyone access to a spare caliper that can be used to make a mock up or a casting ? Doesn't have to be in working order as it won't actually be going on the car
interested in seeing if this will work with the jdm wheels but don't really want to fork out on loads of stuff before finding they won't fit
