the time has come!
as the title says the time has come for me to finally get the turbo on the road (only had it since last july).
but however i have an issue with one or more of the doors not staying unlocked when i use either the fob or the key i have read online that it may be the "door lock remote" but i wanted to come on here and ask you guys what you thought it may be as i have had the most helpful and friendly advice
if you need more details let me know and I will try and explain as best as i can
thanks in advance
4758nigel
problem has been solved it was a false alarm it turns out that it was the alarm in safety mode as it's the sigma but luckily i had the code for the pad so all is good again now
easy fix then :D
luckily yes but unfortunately i discovered that one of the springs in the dump valve has snapped so either i need to replace the spring or the entire valve :(
Ouch which dump valve is it ?
