Hi guys couple of questions
1 had a full decat system fitted been fine for three weeks now the oxygen señor has heater element fault so need to fit a new one obviously but will it fail again as a result of having a decat on
2 turbo comes in but doesn't boost to full pressure until five thousand rpm boosts to 14psi then drops straight to 12 psi and holds at that is this normal
Sounds like it needs a remap as the turbo will be expecting some back pressure from the cats. It will also get rid of the eml that's being thrown by the O2 sensor and you'll be able to have the boost come in earlier with no spiking
Where's the best place to get that and pretty cheap really as I've seen some prices and there rediculous
If your in the northwest could email Andy Carr, or Andy forrest .to see what options they can do for you
Most mappers are willing to travel, there's open source software called carberry which is cheaper than ecutek as you don't have to pay the £150 licence fee
Do you have any contact numbers buddy for anyone
Is it best getting it done sooner than later
Best if emailing then as most of them are out mapping pretty much all the time
Www.teamcarr.net
Just goggle Andy forest & bob rawle as I don't know there details
How soon is you mot due ?
Do you gave a boost gauge or are you using an OBD scanner to get your reading ?
Ok, well if you don't get the engine light sorted before the mot it will fail. You'll need a friendly tester if it foesn't have a cat in anyway
you can also get an 02 cheat sensor adaptor which sits the sensor back a bit so its not directly in the pipe causing issues like eml and will still do its job
