Bennyboy Posted April 5, 2015 Share Posted April 5, 2015 Hi guys couple of questions 1 had a full decat system fitted been fine for three weeks now the oxygen señor has heater element fault so need to fit a new one obviously but will it fail again as a result of having a decat on 2 turbo comes in but doesn't boost to full pressure until five thousand rpm boosts to 14psi then drops straight to 12 psi and holds at that is this normal Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
stants Posted April 5, 2015 Share Posted April 5, 2015 Sounds like it needs a remap as the turbo will be expecting some back pressure from the cats. It will also get rid of the eml that's being thrown by the O2 sensor and you'll be able to have the boost come in earlier with no spiking Quote Link to comment Share on other sites More sharing options...
Bennyboy Posted April 5, 2015 Author Share Posted April 5, 2015 Where's the best place to get that and pretty cheap really as I've seen some prices and there rediculous Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
stants Posted April 5, 2015 Share Posted April 5, 2015 If your in the northwest could email Andy Carr, or Andy forrest .to see what options they can do for you Quote Link to comment Share on other sites More sharing options...
Bennyboy Posted April 5, 2015 Author Share Posted April 5, 2015 Crewe I'm from matey Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
stants Posted April 5, 2015 Share Posted April 5, 2015 Most mappers are willing to travel, there's open source software called carberry which is cheaper than ecutek as you don't have to pay the £150 licence fee Quote Link to comment Share on other sites More sharing options...
Bennyboy Posted April 5, 2015 Author Share Posted April 5, 2015 Do you have any contact numbers buddy for anyone Is it best getting it done sooner than later Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
stants Posted April 5, 2015 Share Posted April 5, 2015 Best if emailing then as most of them are out mapping pretty much all the time Www.teamcarr.net Just goggle Andy forest & bob rawle as I don't know there details How soon is you mot due ? Do you gave a boost gauge or are you using an OBD scanner to get your reading ? Quote Link to comment Share on other sites More sharing options...
Bennyboy Posted April 5, 2015 Author Share Posted April 5, 2015 Boost mate mot in May Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
stants Posted April 6, 2015 Share Posted April 6, 2015 Ok, well if you don't get the engine light sorted before the mot it will fail. You'll need a friendly tester if it foesn't have a cat in anyway Quote Link to comment Share on other sites More sharing options...
Rick 2014 Posted April 6, 2015 Share Posted April 6, 2015 you can also get an 02 cheat sensor adaptor which sits the sensor back a bit so its not directly in the pipe causing issues like eml and will still do its job Quote Link to comment Share on other sites More sharing options...
Rick 2014 Posted April 6, 2015 Share Posted April 6, 2015 Like this one http://www.ebay.co.uk/itm/NEW-UNIVERSAL-02-LAMBDA-OXYGEN-EXHAUST-SENSOR-ADAPTER-M18X1-5-120-DEGREE-ANGLE-/231095373424?pt=LH_DefaultDomain_3&hash=item35ce5b8e70 Quote Link to comment Share on other sites More sharing options...
eddie555 Posted April 6, 2015 Share Posted April 6, 2015 Have you tried ABP. motorsports in Crewe? http://www.abpmotorsport.co.uk/ Quote Link to comment Share on other sites More sharing options...
