Engine management light will not go out
Still got the engine management light on after fitting a new oxygen sensor and also put the cat back on still coming up with the same fault
Heater element malfunction in the oxygen sensor had an electrician check everything and everything is ok wiring loom wise even the old sensor is good
Any ideas would be much appreciated
I have the same problem well similar getting it checked today will offer advice if I have any! Wish me luck!
Which model is yours
there is 2 on the bugeye
I've just looked and yes there is two
Are they the same sensor
I think it throws the same code it's the bank from my understand if it's 1 or 2 depends which one it is but don't hold me to that :)
What code have you got mine is the one before the cat
It's definitely the one before the turbo on mine had it tested and its blown no Heater circuit plus it's the original one by the looks of it so that's another 100 pound to spend [emoji30]
Gutted but keast you know I guess.
have you had the code reset after the new part was fitted, if not that could be your issue, unplug the battery fro 15 mins and that should reset the ecu as well :)_
i do have a decat downpipe that will fit yours if you wanted :)
All sorted now sensor before the turbo cured it thank god 300 pound in a week I've spent
Now I need a decent exhaust system as I don't like the sound of the miltek system that's on it
