Power surge
Hi there.... Just wondered if anyone out there personally or knows of anyone that has had this or similar issue.... Any info feedback would be much appreciated....
Have a 2002 bugeye impreza... When I got this car to begin with it run perfectly... But as of late this problem has got worse.. When putting my foot down the power seems to surge like it comes in and out not sure it this could be a problem with the turbo or engine management I suppose could be anything but help if any one can help would be great thanks
When you say serges does the revs increase 1st then the power follows. ?
Yeah I suppose so... But it's not instant power its fading in and out.... Some gears are ok though just don't know what it could be
Clutch slipping maybe go in third gear give it some acceleration see if it does it then. Other way I've been told to try was start the car. Put it in gear with the hand break on and go to pull away. If it stalls its ok. But I'm on my 2nd clutch now from owning the car and it stalled every time even though the clutch was slipping.
Hmmm I will try that for sure but I really don't think it's clutch related I'm thinking perhaps more turbo? But thank you for your advice will try that!
Could be turbo if when it's spinning its loose and catches the side making boost drop off. But would have thought be a bit more constant through all gears.
