Coolant leak HELP!
betchers
As stants said would be my 1st guess the rads decided to go or the bottom of the hose has split. Check your coolant levels though before driving home probably was already going to do that but just incase :D
Mine showed no signs of going started her up one evening was warming up when it started to **** out of one side, couldn't actually see where from or replicate it when I filled it with water so the pressure must have been forcing it out,
Www.importcarparts.co.uk will have a new one for around a ton should get it next day too
Well another piece of good news, I had a leak test done on the head gasket, that came back negative and once again it is back to the expansion tank, does anybody know where I can pick up an aftermarket expansion tank?
