Engine splutter / stutter under power
Does anyone have any idea what is causing my fozzy 2ltr s turbo import to stutter under acceleration, sometimes the engine jolts like it has tried to cut out but that is only for a milly second.
Drives fine under normal acceleration but press the pedal to the metal and then stutters / splutters then clears, doesn't do it all the time either but it is becoming frustrating.
Recently serviced ! been doing it ever since, could it be; plug gaps, fuel filter or maf , would appreciate any suggestions or fix its.
thanks
blue
Process of elimination pal I'd say I had the same problem on my Bug. Changed the plugs it was no better gave the maf a quick clean and bingo had it cracked. Good luck.
