Coolant temperature sensors location ?
Hi guys anyone know where the coolant temp sensor is on a 2004 impreza wrx, i thk its under the alternator but theres two under there, is it the sensor facing down to the ground or the sensor facing to the back of the car ?
Hi mate, not entirely sure as there should be a crank angle sensor under there at 90° to the top of the block, possibly red plug if I remember correctly, can you get a pic up ?
I've moved into the engine section should get a better response there [emoji3]
Hi stants i jus tried getting a pic, bit to dark under the alternator, il get a torch later :)
Hi stants i got a pic but cant figure out how put it on here haha
Ah ok are you on tapatalk or desktop site ?
There's sensor above and below a hose i thk its the one above ?
If u can see in the pic lol
I can see it [emoji51] i'd hazard a guess ti sat it's the one going directly down but I'll have a further dig around
Thats what i thought until i seen that pic, i know thats for a forester but it look similar ?
I thk the coolant sensor goes into the cross over pipe which the top one does look as if it does ?
I forgot about oil temp sensor so the oil temp straight into block downwards, crank sensor goes right side of pic an the water should be the one that's facing away in your pic towards the rear of the car
Yeah i think so :) god i hope it fixes this prob, so weird how my heater fan control makes the temp gauge on dash drop lol i dont like it :/
