fitting brakes
hello guys im going to replace my discs and pads all round. Ive never done a subaru but have done a type r is it mainly the same just open caliper etc take off and replace, also do i need to change any bearings like the golf mk2 on the rear. help.
Simple mate, pretty much what you described,shouldn't need to change the bearing unless it's noisy ?
Easy mate have to remove the caliper 2 bolts good to go after that. Only problem you might have is if you get a sticky piston :( they can give you headaches but I'm sure you would have noticed if you had one but now so should be good to just swap over without too much bother :)
it's fairly straight forward, the only problem I had was one disc was stuck on, had to use an M8 bolt through the threaded hole to push it off
