I am looking for good condition pair of lower wishbones (front) for my forester SG 2003 2.0 AWD. No after market versions available, can anyone help please?
Disintegrated when being driven. Found out this issue was the subject of a recall in 2012 so looking into this at the moment as the fault it is exactly what happened to ours.
Thanks for the reply though.
Yes they can corrode from inside out, main difference of recall part was anti rust wax treatment to the inside
Hopefully subaru will offer you something if vehicle shows not to of had the recall done.
If not sourcing the alloy wishbones from xt or sti is way to go.
No recall done on the car have messaged Subaru UK about it but if no joy alloy was my thought too.
Thanks for the advice
Good luck with Subaru dealers :-S some will be more flexible in offering support and as a major safety item they should be dealing with it no quibble as parts are cheap to them & it easy fit too.
You should be able source some used alloy ones though so won't be too bad :-/
Thanks for the tip, have had them both replaced under the recall although cost me £270 to get the car transported to a Subaru dealer after I found out about the recall as I did not get the original notification. Guess what? They won't reimburse me!
