Spoiler fitting? Can I replace/repair? Plus moisture in light issue.
Hi all, a couple of issues.
Pictured below is a fitting strap type thing that has gone rusty. I ideally want to replace or if not replace do up. Does anyone have any advice?
Also, another picture below shows I have moisture in the light? Is it possible and simple to remove the moisture? I am planning on getting some spares but wanted to know if this is doable.
As always, thanks all.
Don't think you can get the straps anymore
Maybe some black hammerite type paint them. Are they removable?
If it's not visible on exterior then I'd say hammerite for rust issue. If it is, work on removing but then would be repair and paint job.
mine are just hammerited !
the fog lamp looks like the seal has gone, could try pop the glass off then try reseal with clear silicone sealant
They are pretty visable straps so will paint them with hammerite. I take it they look ok matt?
Yeah fine mate but my spoiler is a bit bigger so covers them bit more
