Sigma S32 Codes
Not my find so thanks to. Ryan85 and the Original poster.
PLEASE MAKE SURE YOU KNOW YOUR PIN BEFORE YOU TRY THE ANTI KEY THEFT CODE - YOU NEED THE PIN TO START THE CAR!
Standard user controls
Ignition Must be ON, not on Accessory power
0 - Last Trigger Isolation --> Allows the alarm to ignore the last sensor that caused the alarm to sound.  Effectively used to disable faulty sensor but still turn the alarm on
1 - Turns off the alarm arming tone for the next time used (if tones are set)
2 - Turns off the ultrasonic sensors for next time used
3 - Turns off the sensor prewarning feature for next time used
4 - Turns off the single and dual trigger sensors  for next time used
5 - Turns off the ultrasonic, single and dual trigger sensors for next time used
6 - combination of 4 and 5
7 - switches safety lock on/off (so car locks as you turn on ignition)
8 - display battery voltage
9 - nothing
* - toggles volume of prewarn beep
To make the passenger door unlock at the same time as the driver door:
Ensure ignition is off, driver door left open. Hold the lock and unlock buttons together for about 5 seconds (it will issue a beep)
Super secret squirrel programming codes
To use : Ignition must be off
Reset to default settings:
*17856*880#
Auto arm with door locking 60 seconds after the last door has been closed, Note make sure keys arn't in the vehicle:
*17856 wait for the beep *004*1# turns it on. everytime a door is opened it will beep twice to inform you that its active
Auto arm without door locking 60 seconds after the last door has been closed:
*17856 wait for the beep *003*1# turns it on. everytime a door is opened it will beep twice to inform you that its active
door unlock/locking beeps:
*17856 wait for the beep *000*1# turns the beep on when locking and unlocking although admittedly not very loud
*17856 *002 * 0 or * 1 then #
Turns on safety locking through the programming code (similar to pressing 7 in the user options) but with more options on lock timings and pulse
*17856 *005 * 0 or * 1 then #
Auto-Rearm & Relock (if the alarm is turned off but no doors are opened etc)
*17856 *007 * 0 or * 1 then #
Accessory Wire 4 Function
Can be used for boot release upon button hold or can be configured to allow Remote Engine Start/Stop devices (such as turbo timers i guess).  If you need more info please ask
*17856 *008 * 0 or * 1 then #
Accessory Wire 3 (Total Closure) Operation - on Arm
*0 = “Timed”. A passive, timed negative output is provided on Acc. Wire 3, every time the system is armed, to operate Total Closure (Total Closure Time *121 must be adjusted from 0 to select the output period if required). When held on arming, TX button 1 still operates Panic.
*1 = “Hold Down”. A negative output is provided on Acc. Wire 3 only whilst TX button 1 remains held on arming after 3 seconds, up to a maximum of 26seconds
(Total Close Time *121 will not affect the output time) When *1 selected, panic can only be operated from optional 2 button TX
NB: Only S30 & 34 models.
* 0 (“Timed” & Panic)
*17856 *009 * 0 or * 1 then #
Extend Standard CDL Lock Pulse - On/Off (only when TX button 1 held)
Can be used with the above or as an alternative total closure option, where the vehicle already has a total closure circuit that can be operated from the standard CDL lock connections. When switched on, the Std CDL Lock pulse is extended (second pulse in the case of double pulse settings) as long as the TX button remains pressed, up to a maximum of 26seconds.
* 0 (off)
*17856 *010 * 0 or * 1 then #
Arm/Disarm Indicator Flash - On/Off
For both radio key and direct switched systems
* 1 (on)
*17856 *011 * 0 or * 1 then #
Accessory Wire 8 Function -
*0 = Internal Panic Circuit. Configures system to activate Panic Mode whilst an earth input is detected on this wire.
*1 = Closed Loop Protection. Configures system to trigger when the circuit
becomes open when armed.
NB: Only S1, 4, 30, 32 & 34 models
* 0 (Internal Panic)
*17856 *012 * 0 or * 1 then #
Positive Door Switch Input or Internal Panic Circuit
12v input is detected on this wire.
*1 = Positive Door Switch. Configures system to trigger when the circuit becomes
12v when armed.
NB: Only S12, 30, 32 & 34 models
* 1( “+” Switch)
*17856 *013 * 0 or * 1 then #
Key Theft Protection - On/Off
NB: Only S4, 30, 32 & 34 models
* 0 (off)
*17856 *014 * 0 or * 1 then #
Accessory Wire 6 (Headlamp Illumination) Operation -
*0 = Arm Only. Configures the timed output to occur only when the system is “actively” Armed (illumination does not occur when Auto-Arming or Auto-
Rearming).
*1 = Arm & Disarm. Configures the timed output to occur when the system is both “actively” Armed & Disarmed (illumination does not occur when Auto-Arming or Auto-Rearming).
NB: Only S30, 32 & 34 models
* 0 (Arm Only)
*17856 *015 * 0 or * 1 then #
Accessory Wire 1 Function -
*0 = Alarm Armed Output. Negative output provided whilst the security system remains armed.
*1 = Total Closure Output. Negative output on arming, this can be “timed” or on “hold down” adjustable using *008 and *121. Wire 1 then behaves and can be adjusted as Wire 3 would be if fitted.
NB: Only S4 models
*0 (Armed Output)
*17856 *016 * 0 or * 1 then #
Accessory Wire 2 Function -
*0 = Aux Siren/Pager Output. Negative output provided whilst the security system is triggering.
*1 = Total Open/Boot Release Output. Negative output on disarming, this can be “timed” or on “hold down” adjustable using *006 and *122. . Wire 2 then behaves and can be adjusted as Wire 4 would be if fitted.
NB: Only S4 models
Original source.
http://www.gt86.org.uk/forums/topic/2846-gt86-alarm-unit-programming-codes/
