Right cut a long story short. changed my sub frame bushes few weeks ago then had what I thought was a wheel bearing issue. I then thought it could of been a diff bush problem as had a low humming noise, I changed diff oil and put anti slip in as well. Then went to Blackpool yesterday went ok there. got in car to come back and the car when reversing felt like it had a handbrake on carried on and set off I got a loud humming noise and a clicking from centre of car which increase on speed. I think I have a lot of play in prop,  as I never had this prop of the Impreza the one on that felt like it had little play. am I right in thinking that even being different prop it should feel same. I am now thinking of changing prop first then diff and bushes as low on money. :wacko: any other ideas may help my cause.
If the humming gets louder as you speed up would say rear diffs had it. Other then that I would have said bearing 1st myself. Have you checked the break pads and disc see if there worn down or grinding I know they can make a nice loud noise.
new pads on back for calliper not checked the pads inside but the handbrake works fine and I can push the car forward and back. I am thinking it is diff myself but don't want to go down that road just yet. :(. May look at brakes when wheels come off for the prop. thanks for post I hav looked around and it look like they are weaker than the impreza ones. As never heard of it while I had them.
:( yeah I know what you mean I get like that when anything starts to make a noise. I think it's worth looking at the breaks just to make sure. But signs do look like the diff :(
if you need any help with owt bud just gimme a shout, i would look at the doughnut ring bearings, try some wd in there, if it goes away for a while or even gets just a tad quieter then theres your problem
will be changing them as well when diff off.  y you telling me the god of wd40 to use it :D there is a full can under there :lol:
i did think that as i was typing :lol: has that made no difference?
the Scooby now has a dog box on the back :D  :(  :(. it is now banging at the rear end at slow speed. I am waiting part and my hols to fix it. so work and back is all I am doing.
when's your hols due?
just dawned on me that you are sat in my living room as i typed that :lol:
didn't you think to text him while he was there
The odd thing is I still didn't ask him to his face lol
lol thought you went quiet.... two weeks.
Cool, gimme a shout when your doing it and I'll pop round
