Subaru forester oil leak
Hi new to the forum, hopefully posted in the right section.
I have a subaru forester 2001, just noticed a burning oil smell, i opened the bonnet and seems to be a very light oil leak dripping on a heat shield at the front end drivers side.
further investigation seems to be coming from a black plastic cover at the front end of the engine which is held on by 3 bolts.
Anyone shed any light on this to what it could be.
Thank you. :(
Typically, on the boxer engine the rocker cover gaskets can weep with age as they get brittle. Due to the configuration this causes it to drip directly on the manifolds, which sounds like your problem
Hi thanks for your reply, the heat shield that i am talking about is at the very bottom, is that covering the exhaust, also the black plastic cover i mentioned any idea to what that is.
Than you
