Subaru sti headlights won't work low beam
Can anyone help I have a Subaru sti 2003 and I had a hid kit on it, took it of put the original bulbs back in and they don't work but the hid kit does. nothing wrong with the fuses or relay or bulbs!!! HELP on low beam
Have you put them in the headlight or tested before refitting?
I've tested them before putting them in the headlight haven't put them in the headlight if that makes sense
Also on 2003 blobs it's a single wire for the bulk. Red connects to spade on bulb black connects to bulb body via headlight make sure you got the cables in right place if you do take voltmeter and test it with lights turned on.
As Steve said wont work unless in the headlight with the Earth connection, pop them in make sure they've got an earth and give it another go
