Hi guys I own a Impreza (08) WRX STI 330s and I've had a couple of warning lights pop up, the engine management light comes on permanently, the traction control light comes on yellow permanently, the sports button flashes and so does the cruise light flashes
does anyone have an idea of what this means ?
thanks in advance
hi,if all them lights are coming on has anyone had the clocks out check the connectors is in right if they have,if not could be clocks going faulty,electrics problem :unsure:
You havnt started it with the maf disconnected I did this once by mistake after changing a sidelight bulb
