Window Trim
Anyone shed any light on what holds these bits of trims that go round the rear windows? I want to repaint the rear section but don't fancy snapping them as not sure what holds them on
screws about every six inches and a couple of pull clips, just remove the door seal and you will see the screws... they are one piece front to back.
