i have just got myseld a subaru legacy and have notice everything works on the sat nav apart from when you go to put a destination in...does anyone know how to solve this problem?
Might need a bit to go on. What model Leggy, and what happens when you go to put a destination in? Do you have the home screen (map) visible, or nothing at all?
  • 2 months later...
hi ,I know this is a late reply but you may need to check when you press menu and it goes to destination ,look at the map of Europe and make sure the uk is highlighted. if not just press change underneath and choose uk. hopes this helps ( if you haven't worked itout already)
