My knock sensor is still retarding my timeing by 6 degrees but only now and again
I'm running on 99 fual
It has a new knock sensor
There are no air leaks
It's had new plugs
It's got the old to new coils on
Just had an oil change
Help
6 degrees isn't much and I wouldn't be that worried, mine typically pulls 2-3 degrees and that's with all new engine, gearbox mounts & pitch stop so maybe it's just picking up background noise too ?
Have you reset the ecu since you changed the sensor ?
