Phillip1993 Posted June 25, 2016 Posted June 25, 2016 My knock sensor is still retarding my timeing by 6 degrees but only now and again I'm running on 99 fual It has a new knock sensor There are no air leaks It's had new plugs It's got the old to new coils on Just had an oil change Help
stants Posted June 25, 2016 Posted June 25, 2016 6 degrees isn't much and I wouldn't be that worried, mine typically pulls 2-3 degrees and that's with all new engine, gearbox mounts & pitch stop so maybe it's just picking up background noise too ? Sent from my SM-G930F using Tapatalk
Phillip1993 Posted June 25, 2016 Author Posted June 25, 2016 I will try and change them it just seems it pulls down the power a lot
stants Posted June 25, 2016 Posted June 25, 2016 Have you reset the ecu since you changed the sensor ? Sent from my SM-G930F using Tapatalk
Phillip1993 Posted June 25, 2016 Author Posted June 25, 2016 yes one thing i an still confused about is why it only happens now and again
stants Posted June 25, 2016 Posted June 25, 2016 How's the 02 sensor ? Sent from my SM-G930F using Tapatalk
Phillip1993 Posted June 25, 2016 Author Posted June 25, 2016 sorry new universal one of them as well (forgot that)
