Blob Jacking Points Front
Please can someone post a picture/photo of the trolley jacking points at the front of a blob wrx saloon if I only want to raise one corner at a time please?
I put trolly jack on their mate on any car when only liftin 1 front corner.
Can you tell from this pic what this is I used at the osf corner yesterday? It's just behind the wheel arch
Does that run down car like a chanell if so thats were i put the jack stand if its what i am thinking of.
It only starts just to the rear of the front wheel arch then goes forward towards the front of the car - I was assuming it was part of the frame so used it on that basis.
What was your picture of - I couldn't see anything like it near either front wheel
Its the plate were the wishbone attach's to the car its were the footwell is just behind the rear of the front wheels.
Thanks mate; I'll have a closer look again tomorrow before I start putting the rest of my mud flaps on.
Just worried I'm jacking where I shouldn't, due to my lack of know how [emoji15]
Dont hurt to ask mate.allways someone to give advice.best i can say dont jack it on sills or floor of car.if it looks solid nice thick plate then sould be ok to jack.thats why i use that nice thick plate.i'll take a better picture in mornin if you need it as am fittin mudfaps as well in morning.
thanks fella, that would be great
Not the best pictures mate.but hopefully help you.taken from rear of car.1 the plate for jack on lower wishbone and second is the channel runnin down car that is what i put axle stands on.
Cheers mate. Got the dogs at the ooh vets at the min but hope to get on with things later
Flaps are on; couldn't find anything like that first pic so used where I'd found yesterday without incident. Will observe where it gets jacked by my tyre man when he puts my winters on.
Using rear diff for back end was fine.
Thanks for all your help...Google wasn't my friend this time lol [emoji106]
Can you spot anything here i should have been jacking from?
That's never been under sealed dave I suggest you either do it yourself of or look into paying someone keep it all rust free
Thanks mate...off work in 2 weeks time so will get my local indy garage to do it [emoji106]
Think I'm going to get one of those ice hockey puck type rubber pads with a channel cut out for future and just jack the front corners at the scissor jack points with my trolley jack using that
Booked in for under seal on 29th [emoji106]
