2001 WRX 2.1 STROKER BUGEYE WITH LOADS OF UPGRADES
£7000
had over 15k spent since I got her at 125,000 with Some service history when I bought her in February of this year (car was completely standard). Forged 2.1 stroker engine was fitted at 125,000. It was bedded in with NO boost for 1500 miles
Guys get real. This isn't an Halfords special. It hasn't ben put together with electrical tape in hopes that it will stay together. DO YOUR RESEARCH!!! This car is the result of a lot of love, money & will power. It isn't at it's fullest potential and it isn't at its lowest. Anyone wanting a great base for their own take on a show car then here is your chance. Please don't insult me by offering me your pocket money from your girlfriend cos she probably only gives you enough to run this car for a few days. The price is the price and is a steal at that. If you have half a brain and even only half a clue with half a Brian you would still understand and appreciate this car and the work that has gone into it.
IF ANY OF THAT ⬆️ ABOVE IS YOU WITH DREAMS AND NO ACTUAL INTENTIONS OF PURCHASING THEN PLEASE DONT READ ON. TURN BACK AND GO LOOK AT THAT CORSA 1.2 YOU WAS JUST CONSIDERING BUYING [emoji6]
Car was mapped by Andy Carr and was done on a live map so no print out unfortunately but he did max the injectors out and said with bigger injectors this car would be faster. It has launch control, anti lag and duel map (around 260bhp @0.7 bar or around 400bhp @1.5 bar)
Full 12 months MOT as of 3/9/16
ENGINE
Here's the spec of the engine:
the bottom end spec will handle 550+ bhp easily.
INDUCTION HARDENED 2.5 NITRATE COATED CRANK
LATEST GENERATION
FORGED PEC STEEL RODS
STANDARD LENGTH
FORGED MANLEY PLATINUM SERIES STROKER PISTONS
SUBARU GASKETS
ACL RACE BEARINGS
NEW RCM OIL PUMP
SCDB- STI 7 BLOCK HALFS USED
STI 9 UK AVCS HEADS
MEGAN RACING POLYBUSH ENGINE MOUNTS
STI PINK 550cc FUEL INJECTORS
TD05 big 16g billeted TURBO, COVERED APPROX 5k
Built by craig bellworthy
STI TGV DELETES
STI INTAKE MANIFOLD
(ported & polished)
GRADE B7 PLUGS
NEW SAMCO SET IN PINK
PINK POWDER COATED INTAKE MANIFOLD
CARBON INDUCTION KIT, direct feed through the headlight.
ROCKER BREATHERS
FORGE DUMP VALVE
JAPSPEED BLACK FRONT MOUNT INTERCOOLER
NEW ALLOY RADIATOR
BRAND NEW 6 PADDLE CLUTCH FROM CG MOTORSPORT 600 miles ago
S/S STI OUTLET MANIFOLD & STI UP-PIPE
TOYOSPORT 3" DECAT DOWNPIPE EXHAUST
CAT BACK STRAIGHT
THROUGH TO BACK BOXES (COBRA CUSTOM TWIN PIPE) sounds distinctive compared to all other Subaru's VIDEO LINK AT THE BOTTOM OF THE ADD
SHORT SHIFTER
STI STRUT BRACE
CUSCO REAR STRUT BRACE
BCR FULLY ADJUSTABLE COILOVER SUSPENSION
ANNODISED BLACK & PINK DRESS UP KIT NUTS BOLTS.
CARBON FIBRE RADIATOR SHROUD
BATTERY RELOCATED TO THE BOOT
POLISHED FUSE BOX COVER
STI PINK HEADER TANK CAP
MISHIMOTO PINK ENGINE OIL FILLER CAP
MAGNETIC SUMP PLUG
BRAND NEW BATTERY BOUGHT LAST WEEK READY FOR THE WINTER
My car gets serviced every 3k AS THIS WAS MY DAILY, she is now sitting in my neighbours drive as I have bout another car and don't want to put more miles on this year.
Service history all present & correct.
TRANSMISSION:
6 speed (non Dccd) box
Good for up to 750 bhp and 160+mph
These boxes have been seen to do this and in rare cases- more!!
Box was fitted to my car at 130,000 (same time as the engine) and was inspected with NO negative feedback.
Bought the box when it had covered only 47,000 miles
INTERIOR:
I bought a mint black pro drive interior
Full Clifford 650 advantguard with intellistart (remote start) and turbo timer
2 fobs and 2 keys present
Carbon fibre centre pods/gauges housing
Sit clocks with red rpm adjustable gear change light (clocks show car mileage to be 25k less to original mileage.
Defi Gauges and Ecu- oil temp/boost/watertemp/oil pressure/fuel pressure
OMP black with blue centre steering wheel (blue quick release boss kit)
wrx sti original car mats
pioneer double din 6.5" pioneer head unit with usb, BT, CD, DVD, external memory stick and auto connect, screen faded slightly. Uploads all contacts and has clear audio to and throw when making calls.
tinted windows all round
Blue interior lights
Carbon dipped door trim and centre console trim
Black sunstrip
Go pro attached to the rear view mirror. In with the sale.
EXTERIOR:
HID kit with Angel/halo headlights with LED side lights (tinted)
Smoked/tinted rear LED lights
XXR 18" deep dish alloys with falken azenis tyres and blue rim protectors
4 tyres have plenty of treat
Rear window spoiler (in gloss black, not fitted)
JDM STI front grill, painted in gloss black
(With a deep purple and pink STI badge)
Roof scoop (gloss black, not fitted)
Blue Epman locking wheel nuts
Cobra Twin pipe exhaust
RCM rear drop links in annodised blue
ABW Wide arch kit carbon dipped
CARBON FIBRE rear wing
STI scoop in gloss black
8d carbon fibre bonnet wrap
Goodridge Braided brake lines
Car was fully resprayed only 6 weeks ago (not a !Removed! back street garage either, see last pic) cost £1500
BAD BITS
All cars have them,
The wide arch kit has a few blemishes on them but nothing that can't be dealt with as they're all removable for spraying or dipping again. It's not noticeable unless your really close.
Trailing arms could do with being replaced but I have a new upgraded set with poly bushes and a reconditioned powder coated rear subframe (needs fitting)
she is mint and gets cleaned every week and polished using only the best products chemical guys or poor boys polish sealant and wax.
The boot will need a new wooden floor board, cheap to buy and most breakers or Subaru club members will have a spare.
she is a 15 year old car so not mint but not far off and is a very good example of a Bugeye.
I have mentioned a lot and probably forgotten a fair amount (all good tho)
I have been honest with the ad and can say this is a reluctant sale but I can't justify keeping this car anymore as I'm getting addicted to spending on it lol
Need to get a nice diesel Bmw
This build took me nearly 10 weeks from scratch and turned the car around from a basic **** heap to a real show car/head turner. The car was due to be sponsored by Sick Speed in the USA and is currently representing CG MOTORSPORT at car shows.
SPARES: full suspension (original in great condition.
bonnet scoop and under tray.
Sti twisted side skirts.
NOTE: the private reg will be retained by myself.
Hell of a lot of car for the money.
If I don't get what I want for the car, I'll break it so just message me the parts your interested just in case this happens. Thanks
Text only: 07827224543 for any questions about the car.
ee0a1fcb07fe1853497a92d13cfb34a0.jpg25f0fc178eef7ec27ab0745db3f5ef93.jpgf97e3a728fdfacc6defe7b2b9bfd89b0.jpg4b315b734c6c3c6d884aad0c2d07bce3.jpgfd9bdfeeca57748975d6114d64237e1f.jpg29cfc1614b9cbae7a3191965c09ab113.jpg38612dce53d8d41e83d243682f48bd48.jpg6bdb7bdd9d0d337b886835acfb5877ee.jpgd305afa60a739501161d966dad88d9ed.jpgdd878030c925e2768321ae44426be0d8.jpgf5799903df9205eae992b7d31b3e4c92.jpgf2e0d75dc7d1c31e25dd01f7c741503d.jpgb9fe63549dc90697918870b3ea46cc25.jpg8c1dceca301559c76b30303bd90d5de5.jpgeb7e33abdea579d0709a39bfe9859d3f.jpg17f85ae7b77de353cc0c6cbf2f665f7b.jpga429989972fc809f2ad97e6b16cec679.jpg
Text message me if you have any queries 07827224543
Thanks for looking
Good luck with the sale 🖒 passed me a few weeks back at owlcotes heading towards Bradford sounded good 😂
Good luck with the sale 🖒 passed me a few weeks back at owlcotes heading towards Bradford sounded good [emoji23]
Thanks Stants, just bought a few other cars including a 3.2 Quattro and the kids love it. Will be looking at getting a supra for next year so you'll still see me around in a Jap car [emoji12]. Hope your well and enjoying the new house kiddo. Stay safe and see you around [emoji106][emoji109]
