Power steering issue
Just lately my power steering is becoming an issue first thing on start up. A screech and also a judder when turning the wheel. It's also quite bad lock to lock. Belts are in good condition but I have around 1.5 mm of movement on the pulley backwards and forwards. Do I need a new pump or something simple. 👍🏻 Thanks in advance.
Got same problem but have not checked for movement my friendly mechanic is going to change belt next week.
Sent from my SM-G357FZ using Tapatalk
belt is loose,mine did same,tightened belt 1 full turn on nut,perfect now.wants about same amout off play as your ac belt.
  • 4 weeks later...
Belt needs tightening that's all buddy! Had the same morning screech with mine!
