squeeky wheel
hello can anybody help me when im going along sometimes i get a squeek coming from front wheel only when i let clutch out rolling along when i touch brake it goes then comes back sometimes changed brake pads and callipers not that maybe its wheel bearing on way out anybody had this before
Did you change the disk? If not id check it to see if it has a lip on the edge of the metal before you change a wheel bearing.. if it's when you let the clutch out it could be either cv joint that's lacking in grease round the bearings and sqeeking when it's under drive pressure. If the rubber cover over the joint is in bad shape I'd say that's your cause. Hope you get it sorted.
I'd also check that the stereos up loud enough, sometimes when the volumes down you can hear loads of different noises that seem to disappear when it's on louder.
