LHS/RHS Subframe Torque Settings
hi guys
Hopefully a simple set of answers, can someone please tell me what the torque settings are for the 14mm/17mm bolts that fasten the LHS and RHS  subframe connectors to the subframe and chassis.
I have a Haynes manual but it doesn't seem to include the subframe connectors
There are 5 x 14mm and 3 x 17mm
If it helps info relating to the parts in question can be found in this anti rollbar replacement document I found online
Thanks in advance
Perfect.
Thanks Mr. B, you sir are a star.
In case others need a quick reference:
Tightening torque taken from page 2170 of the PDF from Mr. B's link:
M12 - 17mm  -: 55 N·m (5.6 kgf-m, 41 ft-lb)
M10 - 14mm -: 71 N·m (7.2 kgf-m, 52 ft-lb)
NB: States that the M12 bolts are wax coated and should be replaced.
