Hawk sti oil pressure light
Hello everyone, been a while since I last posted, and quite a lot has changed since my head gasket went 6 month into ownership and warped my heads 😂 2.5l i should add.
Have got a problem with my oil pressure light which doesn't seem to illuminate any more at all, have a oil pressure gauge installed so have good oil pressure about 7 bar cold and 3 hot, have tried unplugging sensor incase it was stuck but still no light, what else could be causing this apart from the led in the dash has failed?
Cheers George
Your best bet is take the connector off and earth it tern the key but dont start if the light is on then its probably the sender thats at fault so a new 1 should fix it
I have tried this and also have fitted a new pressure switch but still no light, is there bulbs in the dash or are they led's on the 2006 models
That's a question for someone else as I don't know but if it is an led I would look and the wiring as it's very unlikely the led is at fault sorry I couldn't be of more help
Sent from my SM-G903F using Tapatalk
