Hi, so on my drive home I had a nice visit from the check engine light, have a had ecu on and getting p0171 which as far as we have looked up could be a number of things, currently checking oxygen sensor, are these easy to replace your self or is it a garage job.... Are the easy to get hold of?
Many thanks
Sent from my A0001 using Tapatalk
Www.importcarparts.co.uk should have what you need, relatively simple job if you can get to it, usually a 22mm spanner unplug the electrical connector and remove
Thank you that's really helpful
Rule out MAF (thorough maf clean), air leaks and fuel supply before spending on likes of a front lambda (don't buy cheap ones).
