Traction control
Well , I'm just wondering if you can map or alter the tc settings using Ecu Tek soft wear or any other piggy back stuff , all I really want is when I go into s# on the so drive , in my case this is my high boost map, I just want the tc to switch off completely when in high boost it's starting to get annoying , had a play with an evo last night , when I thought my car wasn't pulling properly looked at the gauge and the tc light was on all the way through third 🤦🏻‍♂️ nightmare because I never really have an issue unless booting it in high boost . I just want to twist the si drive and that do everything
is their not a button down on dash to turn traction control on and off
Yes but I forget to turn it off and would rather it did it automatically when changing maps
