forester xs navplus D cranck failure
Can anyone advise me , i have  a forrester 09 deisel xs nav plus D with a banging crank and leaking crank end seal. I am told that the only route to fix this is via a short engine for about £5,000!!!! is it possible to get the bits and fix it myself. i am having trouble identifying all the exact bits i need and also the settings for the assembly, can anyone help point me in the right direction here or is the short engine the only route forward?
thanks
Nick
Hi welcome to S.O.C forum :)
And as for you're problem probably better asking other sections of the forum really as this is used to to introduce yourselves so many times gets over looked. I'm going to pass the book with this as I'm not to sure myself and I'd recommend ringing a chap up at Sheffield Subaru services for his advice I appreciate not local to you bu hes a top bloke and would maybe be able to advice better than me.
0114 243 0099
