overheating issue
hi any help appreciated...
i have a 04 wrx,
this afternoon i noticed the heaters in the car started blowing cold and the temp gauges went up high,turned round to come back home and after a min or so the heaters went warm again and the temp gauge went back to the middle.
so i drove for another 5-10 mins,the temp stayed normal and the heaters were working,so decided to pull over and turn the heaters off and let it idle for a 5 mins and watched the temp gauge ,temp stayed normal so i turned the heaters back on and they were hot,and set off back home.
the temp stayed fine for about 2-3 mins then the heaters went cold again and the temp went up again.
when i got home and pulled into the drive i let the car idle for a couple of mins,the temp stayed high but did not rise , i also heard the engine fan on.
not sure whats going on so any help would be appreciated
thanks.
I think I sorted It!
Never thought to check the coolant level,I only picked it up on Sunday...it was nearly empty!
