Brake bleeding
Ok guys so i have changed my brakes from slider ti the 4 pot front calipers and fitted new pads,pedal still feels a bit soft and spoungie.when changing front pads do you just bleed front calipers as i have read you have to bleed all four corners of car in a diagnal order because of the abs.i never bleeded brakes with disk on back as well.so questiin is do i need to do all four or just front two.cheers.
All 4 mate, start furthest away from the master cylinder and work round
Cheers mate.just wanted to check so i was not wasting time doing them again wrong [emoji23]
[emoji23] I was also told by someone to bless them go for a drive stamp on the pedal so the and kicks in then 're bleed, seems a bit excessive & I never had a problem not doing it that way
