Its Time To Bite The Bullet
So......
The time has come to bite the bullet......
Big end gave up the ghost on the old girl at 119K just let go on the motorway one weekend,
I bought a second engine which has been its own whole dilemma, and now it looks like that is a dud (wrong engine the lot)
So I'm going to rebuild the original engine. So the big question is what do I need?
im looking at a full engine gasket set, bolt set, looking at a crank with main bearings/thrust bearing and big end bearings new head bolts, inlet and exhaust gaskets, Cam Belt with the view to re-use the new pulleys/tensioners oil and water pump I just installed. Inlet and Exhaust Guides, New Little end bearings with clips.
anything im missing? apart from sense
